peteresquino1 avatar image
peteresquino1 asked
Invertor Does not operate and LED Flashing
My Victron easy solar 500va 48 volts tripped and the leds are flashing , bulk absorbtion and float flash together with inverter on , and the low battery remians on ,then the float stays on and the bulk flashes with the invertor on and the low battery stays on . Can anyone help
led
timzim avatar image
timzim answered ·
I’m not familiar with the 500VA/48V easysolar, but my suggestion would be to switch the inverter/charger off, disconnect the solar and leave the system off for a couple of minutes. Then switch the inverter/charger back on and reconnect solar. That should reset things and hopefully resume normal operation.
