lambish avatar image
lambish asked
Easysolar grounding in vehicle
Hi, i experience some difficults to understand the grounding relay system in a Motorhome. In Many Diagram i've seen the ground (the ground point inside the easysolar panel where Ac in and Out ground should be connected) connected to vehicle chassis, for that OK.
Now, questions :
-Because of the built-in RDC inside the easysolar, should i connect the ground relay? And how?
-In my case i use a BYD Pro 10kw battery. Should i connect the ground of the box to negativ pole and to chassis? Or this already done inside the easysolar?
I don't have à DC distribution bus bar like in the byd/victron diagram ( https://www.victronenergy.com/live/_media/battery_compatibility:byd-example-diagram-2018-07-21.png
In my opinion, it's difficult to find this Kind of informations for easysolar. The diagram always shown Multi and/or mppt etc... Maybe victron can made some specific diagram for easysolar, and the use in a vehicle? (or maybe it already exist but i didn't find it...)
EasySolar All-in-OneGrounding
Hi @Lambish
As in the drawing: grounding regulations can differ due to your region, please consult an electrician for that.
Normally you don't want to connect the negative pole to the chassis, but local regulations might require it.
lambish answered ·
I've already talk to An électricien, my father and à friend, but nö know how it work for installation in a vehicle... And the AFNOR documents about Electrical installation don't say anythingaabout that.
For the negative of the byd battery ok, but for ground relay, should i use it? And how to use it?
Yes! you should use the ground relay! see the multiplus manual about it:
https://www.victronenergy.com/upload/documents/Manual-MultiPlus-3k-230V-16A-50A-(firmware-xxxx4xx)-EN-NL-FR-DE-ES-SE-.pdf
see chapter 4.3
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
