joevanty avatar image
joevanty asked
BMV 712 question...
I installed the 712 and it appears to be working fine. The only thing is, when I am hooked to shore power, or my engine is running, my ah and watts still show negative numbers. I flipped the shunt and the numbers displayed were only positive regardless of weather or not I was on shore power, and the battery never dropped below 100%.
I have since switched the shunt back as per the install instructions. Cant figure out why the numbers are negative while charging.
My settings are:
Battery Capacity :148 Ah
Charged Voltage: 13.2
Tail Current: 2.00%
Charged detection time: 3m
Peukert exponent: 1.25
Charge efficiency factor: 95%
Current Threshold: 0.10A
Time-to-go av period: 3m
installation
Can you give us some pictures and/or a simple wiring diagram of you installation?
joevanty answered ·
Here is my wiring diagram, its a sailboat, lead acid batteries. Shunt is installed between the charger (E) and the house batteries (H). When I installed th shunt, I added about 10 inches of cable.
4 comments
O is the starter-battery? B+ and B- is for DC loads?
joevanty avatar image joevanty Matthias Lange - DE ♦ commented ·
Yes, I believe so.
Additionally, the battery seems to be in a constant state of discharge even when connected to shore power (Charging). I have checked and re-checked that the shunt is connected properly, battery side to the battery and load side to the charger.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ joevanty commented ·
It's a strange wiring...
Without a look at the real wiring I would say the shunt have to be wired like so:
Only in this way you can measure all the current flowing out of/into the (H) batteries
Thanks, that makes sense.
I disconnected the negative wire between the house bank and the engine battery. The monitor is still displaying a drain of -2 amps and -30W while charging. Also...the SOC is falling. That doesn't seem right.
