jdm avatar image
jdm asked
Turning off adaptive charger Blue solar 150/70 & temp compensation ?
Hi All,
I have 2 x 150/70 Bluesolar charge controllers VE.can connected, so settings are only available to edit via the LCD. I am trying to rescue a sulphated battery bank -and as a result I wanted to turn off the adaptive setting in the menu but I only seem to get an hrs value of 1-8. Is there somewhere else I can change this - I was looking for some setting that says 'fixed' .
I also wanted to set the temp compensation to 5mV/C but seems like the max is 3.5 and default is -2.7mV/c. any one out there able to help ?
Thanks in advance.
battery chargingtemperature compensation
Hi @JDM
I don't know about the temp compensation, but you could set the float voltage to a value you want to keep the batteries at.
