Les Rollins avatar image
Les Rollins asked
Victron multiplus inverter charger settings
can anyone please advise which settings to change out of these 6 pages.
Equipment on board is as follows
Victron multiplus inverter charger 12/3000/120
6 × trojan t105s 6v wired to make 12v. 675 amps in total
Absorption 14.7
Bulk 14.82
Float 13.50
Equalization 16.20
Figures taken from trojan website.
980w solar into victron mppt 150/85
No mains power only generators 1 x honda eu20i and a kipor 6.7kva
inverter current draw
Alexandra avatar image
Alexandra answered ·
@LesRollins
Sorry for the late reply. You have let likely solved this by now. At least I hope you have. The following link gives other resources for further learning.
https://docs.victronenergy.com/veconfigure.html#introduction-and-requirements
The table of contents shows tab by tab instructions.
In short, the first 4 tabs must be altered and fifth and sixth are set up specific programming.
Les Rollins answered ·
Thank you for the information I will have a look through it
