Which function and what values are suitable?
The EasySolar contains a CCGX and a Multiplus. So either could be used to configure the automatic starting and stopping of a generator (with its own 2-wire receptive autostart controller).
This Automatic Generator start/stop manual covers the details.
Let me know if the manual is not clear in any parts, I am working to improve it.
I just encounterd the setup of a smartgen controller with an easy solar 24/3000.
I found the relay at multiplus board switched off. then I found the relay at the back of the ccgx. this is the relay the easy solar seems to use by default.
This post helped me a lot with the smartgen controller settings to switch it to xx10 version (autostart) https://community.victronenergy.com/questions/89269/smartgen-generator-controller.html
tnx for the hints.
GX - Generator auto start/stop
3 People are following this question.
