dargatech avatar image
dargatech asked
ECOmulti
Dear all,
I would like to use 3 x ECOmulti for grid tie PV project (3 phases). The description of ECOmulti
is not clear for me. For example I don't know if the unit contains batteries and BMS? What do I need to charge batteries with PV (MPPT controler, inverter...)?
Thanks for your comments, suggestions or shearing experiences or setup !
Best regards
smart solar set-up helpsystem design
Hi @dargatech
The batteries have to be bought separately, as is noted on the pricelist.
A lot of information can be found here:
https://www.victronenergy.com/live/eco_multi:start
You can configure them for 3 phase operation, but you'd have to connect the batteries together also, and you have 2 spare Color Controls as you only need one.
It's probably best to look at the Multiplus II series, or the old or new easysolars.
