botessj@gmail.com avatar image
Where or how do I software lower the kva output of my Quattro?
As a result of municipal legislation, I need to limit the output of my 10Kva Quattro to approximately 4kVa maximum. I believe that this can be done by means of the software, but cannot seem to find the exact settings I need. Could somebody please assist
VEConfigure 3
Do you need to limit the amount of power fed back to the municipality? If yes, it could be done in the ESS settings but we need a bit more info about the system. PV array size, the way the system is set up etc
As far as I know there is no setting to limit the output current/power.
You can activate/deactivate an internal relay if the output power is over/under a specific value but I don't know how you could use such a signal.
Share
