Does it hurt a Multiplus to have it turned on to allow AC pass through with no batteries connected? I am in the middle of battery upgrade and would like to have AC power in the trailer.
31 People are following this question.
Victron Multiplus Ground Issue?
Can a GX access information if 2 Multiplus are on the same bus, but driving two separate AC loads
N/####/system/0/Connected Not accurate / changing & N/####/system/0/Ac/Alarms/GridLost
measuring separate AC power usage from inverter via VRM
Can setting low temp cutoff in BMV-712 stop AC converter charging?
