craig-b avatar image
craig-b asked
3 x Multiplus 5000VA to parallel
I'd like to parallel 3 x 5000VA multiplus together. Would anyone be willing to send me a document on how to do this?
The same system above will also call an ATS of a 20KVA generator in when battery is critical - through a cerbo
If anyone can help with the above info, I'd be most grateful
multiplus in parallel
ejrossouw avatar image
ejrossouw answered ·
The documentation and other reseorces you require is available on the Victron website if you do a search as well as on Victron Professional to which registration is open to anyone.
