petel avatar image
petel asked
BlueSmart IP 22 charging with AGM and LifePo4
I have the above charger with two outlets which go to two separate banks of AGM batteries. I need to change one bank as it is at the end of it's life, if I change it to a LifePo4 battery and set the charger to Lithium charging will it be detrimental to the AGM battery that is left. They are not connected.
battery chargingLithium BatteryAGM Battery
manta avatar image
manta answered ·
I am doing exactly the same thing, what i have done is connect the main AGM battery and maintain the AGM charge setting and use a Orion-TR at a constant output voltage (27.6v) to charge my Lifepo4 bank. This has some disadvantages because all current goes trough the AGM bank but since I am only using this for a couple of months a year it would be no problem.
Battery Compatibility
VictronConnect VE.Bus charging manual
