Hello I have a 160W panel and a MPPT 75/15. The PV voltage never goes higher than 12 plus volts. It never charges. I have tested on a meter the battery and solar voltage. I have had the camper in different spots. One thing I can not explain is when I charge the batteries I see the PV voltage go up as the battery charge goes up.
Thank you for the help.
