path avatar image
path asked
Generator Starter Battery Trickle charge
I have searched the site but can't seem to find the correct information I am looking for, so when you use relay 1 on the cerbo for the auto start on he generator will one of the connections trickle charge the starter battery for the generator and if so which connection please. looking for the correct wiring diagram to connect our generator to our Cerbo GX using Relay 1, including being able to trickle charge the statrer battery in the generator
Generator
Alexandra avatar image
Alexandra answered ·
@PATH
What inverter do you have?
Some have a trickle charger built in (mostly the 12 a d 24v models) and is labelled as such.
The rest like the 48V, you will have to buy a dedicated charger for.
What type of signal does your generator need to start?
https://www.victronenergy.com/media/pg/Automatic_Generator_start-stop/en/which-relay-and-control-to-use-.html
