social-fabric avatar image
social-fabric asked
Multiplus II not connection to mains on low battery voltage
Hi All,
I have a 12V system with the following AC Input Control configuration:-
Connect when SOC drops below: Disabled
Connect when battery voltage drops below: 10.9V - it is this setting that doesn't work!!
Delay before connection: 0ms
Disconnect AC input on: Battery Voltage
Disconnect when voltage higher than: 11.3V
Delay before disconnection: 0ms
I recall it did work when I had the "Connect when SOC drops below:" enabled but I found this method inaccurate with my Ni-Fe battery type (all else works fine). Any suggestions? Thanks in advance...
Multiplus-IIsetupac
Mike Dorsett avatar image
Mike Dorsett answered ·
Try re-enabling Connect on SOC below, but with a very low SOC figure, also set the delay to a non zero value.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
