pietro-baricco avatar image
pietro-baricco asked
Multi RS Solar 48/6000 Error 27
I have installed the system on november last year, and it has worked well so far.
Since yesterday I started getting this error (error 27 charger short circuit) and the multi goes in passthru. Only a power cycle will bring it up again. The firmware is updated.
I have two strings of panels, ~ 280v per string, total kwp is 5.5Kw, or about 2.5-3 kw per string.
Battery is a diy 280ah lifepo4.
Is the thing broken?
Thanks
MPPT Controllersmppt rs
Alexandra avatar image
Alexandra answered ·
@Pietro Baricco
Does your battery have a contactor?
Error 27 for normal mppts
Error 27 for the RS.
Is the error resetting on its own?
pietro-baricco avatar image pietro-baricco commented ·
The battery BMS has a loud mechanical relay that switches off when a cell goes above 3.65v.
This does not normally occur, but I've seen it happen on some occasions.
The error does not reset on its own, to get rid of it I have to completely turn off the unit.
Alexandra avatar image Alexandra ♦ pietro-baricco commented ·
Then i guess according to instructions the ubit has developed a fault, would need to be returned ....
