ako avatar image
ako asked
Smart Shunt Temperature DVCC
I have just installed a Smart Shunt with a the correct Temperature sensor but the Cerbo is still using the other type of sensor that conects the the Negative pole , it cant see the Shun Sensor . Looking at the lis it has Multiplus , Battery Temperature sensor 1 ( the one conected to the negative termnal ) Automatic or No Sensor , no mention of the Shunt .
Also how can i tell if DVCC is using the Voltage from the Shunt or from the Bus bar as berofr Shunt was installed , theres no list showing the options .
DVCC
@AKO
One thing at a time.
Is the temperature sensor on the smart shunt setup as a temp sensor in Victron connect?
Does the smart shunt appear in the devices list on the GX?
Is it set as the system battery monitor?
ako avatar image
ako answered ·
Is the temperature sensor on the smart shunt setup as a temp sensor in Victron connect?.............It is now and i can see it on the list and selected iT.
Is it set as the system battery monitor? . No it apears that its set for Battery Monitor but its greyed out and says Changes are not allowed on remote conections .
Shunt now showing 23c on Victron Connect and VE Bus Sumary on VRM but MPPT stil showing 25c so must stil be taking it fropm the Old temperature sensor
I follower the quick start guide and then through Victron Conect set Battery Bank size , charge Voltage at 0.3 Volts under Asrption and the Tail Current at 1.85 Amps ( .5% of 370 Amps ) 1/200th .
Another thing that puzzles me is that i have always understood Lead Acid batteries to be inefficient and a lot or the charge going into them is lost but it recomends a Charge Efficiency Factor of 95% which seems very close to Lithium at 99% , am i missing something
@AKO
The charge efficiency would need to be what ever the manufacturer recommends.
The agms and gels I think are more efficient than the liquid ones which were at 85% and used alot of power just floating. I also find 95% not so believable. But I havent used any recently so cannot say for sure.
Before you put the shunt in, DVCC likely used the inverter battery terminal voltage.
