hello everyone,
i have a solution for microinverter with battery system i am sharing a picture for all of you and please check that this combination should be work or not and suggest me best solution for me?
hello everyone,
it would be useful if you would add the specs for the micro inverters you intend to use.
here is the inverter technical specification
Micro inverters are not meant to be powered from batteries.
Micro inverters are meant to be powered by solar panels.
What are you trying to make happen??
I used a simmilar setup before I build my "big" PV installation. It was more for testing, but what I figured out was, that it made more sense to connect one PV module directly to one of the micro inverters, and one micro inverter then to the battery.
Of ouf your description we don't really know what is your plan, so what do you want to achive?
But I would guess you want to reduce your consumption from the grid? ;-)
For me it turned out to be a good solution with one dircet feed in during the day, and one (limited) feed in out of the battery at night.
34 People are following this question.
