Leo Blok avatar image
Leo Blok asked
Venus GX don’t reconnect
When my network looses the WiFi connection and then it comes back on again, the Venus GX doesn’t reconnect.
I have to restart the Venus GX to get connected.
Can this be fixed in the next version?
Thx.
wifi
Hi, we have indeed had other reports. And in many situations it does reconnect OK. Its been very hard to reproduce in our R&D: can you easily reproduce it?
Anyway, in the next version (v2.30) there is a setting that makes the device automatically reboot itself if it can't communicate to the VRM Portal.
8 comments
Leo Blok avatar image Leo Blok commented ·
Hello @my router is also the DHCP server. My WiFi network is away from my router and connected with a lan cable.
The strange thing is, when my router fails the WiFi network stays intact except no internet connection off course.
So the Venus looses also his internet connection and the connection with the WiFi network. The Venus uses an DHCP IP address, and it looks like when the Venus don’t see the dhcp server he dropped the connection.
Leo Blok avatar image Leo Blok Leo Blok commented ·
When I give the Venus an static address there is no connection possible.
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ Leo Blok commented ·
Hi, what Venus OS version are you using? Could you try with v2.30~51 ?
See here for how to get that:
https://www.victronenergy.com/live/ccgx:beta-testing
Leo Blok avatar image Leo Blok mvader (Victron Energy) ♦♦ commented ·
@mvader I updated it to v250~51 I set the option to reboot when he looses connection. We wait and see. Thx
@mvader
This morning the Venus looses his connection, and after one hour the Venus rebooted and the connection was back. I preferred a stable connection so the Venus reconnect by himself but this will do for now. Thx.
Morning Blokl, good to hear that works. Yes I prefer a stable connection as well.
To be continued, we’ll look into this somewhere in the coming time.
This is the last log before reconnect /var/log/messages
May 28 08:41:53 beaglebone daemon.info connmand[1440]: wifi0 {add} route 62.179. 104.196 gw 192.168.2.1 scope 0 <UNIVERSE>
May 28 08:41:53 beaglebone daemon.info connmand[1440]: wifi0 {add} route 213.46. 228.196 gw 192.168.2.1 scope 0 <UNIVERSE>
May 28 08:41:53 beaglebone daemon.info connmand[1440]: wifi0 {add} route 0.0.0.0 gw 192.168.2.1 scope 0 <UNIVERSE>
May 28 08:41:53 beaglebone daemon.info dnsmasq[1398]: using nameserver 213.46.22 8.196#53
May 28 08:41:53 beaglebone daemon.info dnsmasq[1398]: using nameserver 62.179.10 4.196#53
May 28 08:41:53 beaglebone daemon.info connmand[1440]: wifi0 {add} route 212.227 .81.55 gw 192.168.2.1 scope 0 <UNIVERSE>
May 28 08:41:53 beaglebone daemon.info connmand[1440]: wifi0 {del} route 212.227 .81.55 gw 192.168.2.1 scope 0 <UNIVERSE>
May 28 08:41:54 beaglebone daemon.info avahi-daemon[1420]: Joining mDNS multicas t group on interface wifi0.IPv6 with address fe80::e9a:42ff:fe19:598b.
May 28 08:41:54 beaglebone daemon.info avahi-daemon[1420]: New relevant interfac e wifi0.IPv6 for mDNS.
May 28 08:41:54 beaglebone daemon.info avahi-daemon[1420]: Registering new addre ss record for fe80::e9a:42ff:fe19:598b on wifi0.*.
May 28 08:42:27 beaglebone daemon.info connmand[1440]: ntp: time slew -0.006186 s
May 28 08:47:10 beaglebone user.warn kernel: [ 1231.937997] RTL871X: set group k ey camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
May 28 08:57:10 beaglebone user.warn kernel: [ 1831.942895] RTL871X: set group k ey camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
May 28 09:07:10 beaglebone user.warn kernel: [ 2431.943193] RTL871X: set group k ey camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
May 28 09:17:10 beaglebone user.warn kernel: [ 3031.948077] RTL871X: set group k ey camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
May 28 09:27:10 beaglebone user.warn kernel: [ 3631.952493] RTL871X: set group k ey camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
May 28 09:37:10 beaglebone user.warn kernel: [ 4231.956702] RTL871X: set group k ey camid:2, addr:00:00:00:00:00:00, kid:2, type:TKIP
Hi Blokl, could you try and see if its solved in v2.31? And then I don’t mean the automatic reboot; I mean if its all stable again without having to fall back to automatic reboots.
It's updated. I keep you informed in a couple days.
Heelo @mvader (Victron Energy Staff) It works well now. When he looses the connection the Venus reconnect by himself.
No problems anymore.
Regards,
Leo
Francesco Pugliano avatar image
Francesco Pugliano answered ·
Hi, the Venus just disconnected and it's impossible to reconnect to the wi-fi using any of my 3 iPhones. I can only connect with my MacBook. It says the password is wrong, but it's not. I double checked in my KeyChain.
michel-marchand avatar image
michel-marchand answered ·
I'm having the same issue every time I power down my Internet. I use Starlink Internet and since it's a remote cabin I shutdown the router at 16h and turn it back on at 8h to save energy during winter time. The Venus will never reconnect to the Wifi but it used to be OK before so maybe it's related to a recent firmware update but that is annoying. I have to power off and on the GX to get it back. I will look at the auto reboot feature but that is a patch not a fix.
bushy111 avatar image bushy111 commented ·
Did you find a solution or did the automatic reboot work for you?
tortuga avatar image
tortuga answered ·
Is there a resolution? I am having the same problem of disconnection then need to reboot to reconnect. My Cerbo is at v2.91 and I am using Starlink.
Thanks
lucca371 avatar image
lucca371 answered ·
I have the same problem with v2.92. DHCP or static IP is no difference. When WLAN router reboots the Venus dosnt automaticly reconnect to WLAN. The only solution is to restart the GX.
It seems to be that with LAN there ist no problem, but i need WLAN.
lucca371 avatar image lucca371 commented ·
The Victron EV Charger works in the same WLAN without any problems. i can reboot the WLAN router the EV Charger is always online and reconnect automaticly.
bushy111 answered ·
Has anyone found a solution to this? I have same problem with Venus GX not reconnecting to WiFi? Im reluctant to turn on automatic reboot as then it will be happening all night presumably while my Starlink is offline. Anyone found a work around?
