okelaa avatar image
okelaa asked
Output difference of Victron temperature sensors
Is it possible to calibrate or adjust the temperature reading?
Below is the chart where two sensors read from the same battery simultaneously.
One below is connected to the SmartSolar charge controller MPPT RS 450/100-Tr is showing -2.2C and the other one connected to the inverter Quattro 48V/5000VA, is showing -6C. However, an independent control sensor is showing -3.7C.
Temperature Sensor
Victron temperature sensor disambiguation table - which product supports which sensor
