Is this documented anywhere? Is there a way people "measure" the amount of insulation to strip off the wire before plugging the PV wire into the MPPT for a best fit?
Hi @AlaskanNoob,
Solar PV input cable insulation should be removed to allow 12 mm of exposed copper into the PV attachment point on the MPPT RS. It should not be possible to come into contact with any exposed copper wiring, the fit must be clean without any stray strands.
I have just added that detail to the manual, but may take a little while to be published.
Please be aware to use very fine stranded cable into that entry, exact spec cable strands for that is in the safety section of the MPPT RS manual.
If this is the case I'm very bummed, but very happy before installing it in a forest tinder box.
Guy thank you very much for that. Can you confirm that the 2800' of 7-strand PV wire we bought and had shipped to Alaska (600V direct burial) is a safety hazard with these charge controllers?
That would be one way to do it, though I don't recommend it either.
You definitely DON'T need replace the entire cable run, only find a junction or switch to adapt from your thick strand cable and allows you to run a finely stranded cable the last yard to the MPPT.
This is the wire we bought for 7 arrays to run between 30' and 140' to the charge controllers.
https://nassaunationalcable.com/products/10-awg-7-or-19-strands-pv-wire-photovoltaic-cable-single-core-2000v
use a ferrule not just bare wire
the ferrule length is just the right length
I've heard many say use a ferrule with Victron MPPTs, but haven't seen Victron mention them in their manuals.
It's odd that 10 AWG PV wire can't be 7 strands according to Victron due to the contact area issues requiring more strands, and yet ferrules are used which you'd think would be like making a single strand in the connection.
Also, I've heard several say not to use ferrules with Victron's spring mechanism as it isn't a good fit.
It would be great if Victron would explain their thinking on the connections more clearly for beginners like myself.
32 People are following this question.
