tochal avatar image
tochal asked
Batterie cells in series
HI every one,
i have 16 LifePo4 Cells, 15 of them are very good but 1 is not as good as others.
the bad one is not so bad to return it , the others are just slightly better.
in which order should i put the cells in series together?
which of the following answers could be correct?
-the bad one next/ before the best one?
-the bad one as the first cell and connected to the (+) pole?
- it really doesn't matter where to put the bad one?
can someone help me please? Thanks
battery
der-neue-hier avatar image
der-neue-hier answered ·
Give more information, what makes the cell so bad or better why do you think the cell is bad
tochal avatar image tochal commented ·
thanks for the answer,
i charged all of therm in Parallel to 3,6 V and then removed the connections and left them (indivisualy and witout any connection ) for 10 days, after 10 days, 15 of them dropped to 3,52 and one of therm to 3,44, so i think this one is the bad one, but i cant return it since i revived them end of December (delivery from china)
