euros avatar image
euros asked
Quattro and BPP no connection
44fb25c9-1107-4bab-92ac-e9e49c24476b.jpegHi
I’ve got an issue where my 10 year old Quattro (24v/5000va/120amp) and BPP are not connecting. I’ve just replaced the boat with new batteries so turned everything off to do this. Turned everything back on and Quattro didn’t come on. This happened a year ago so I disconnected the cat5 cable and the Quattro came to life so plugged the cable back in. The charger and inverter works but the BPP (version 0.0402) shows no connection to the Quattro. The battery monitor side seems to work. Any ideas how to connect? Should I update the software on the Quattro or will this not work with the old BPP? Or should I just replace the BPP to a GX colour but I see someone else has had a similar issue with the GX?
Thanks
Euros
connection issue
