Hi
I'v got an
Victron SmartSolar MPPT 75/15A med Bluetooth
and
Victron BMV 712
connected to One LifePo4 100Ah User
separated with Victron Argo FET 200-3, batteryseparator , 200A
One Lead battery Start battery
I have connected the solar MPT directly on the LifePo4.
I believe that I will loose to much power even over a FET separator and spikes and noise from my engine generator in on output MPPT? Cause they would have to be connected on the same input at Argo. But that means that I can not use solar to maintenance charge start battery?
I have an battery charger connected into the Argo also.
Regards Haakon
