miloajr avatar image
miloajr asked
Issue with overcharging (2 x 12v 200ah lithium)
Greetings friends
I live on a houseboat and I’be just had a multiplus 24v 5000va 120 amp installed with 2 lithium Batteries. preparing to install solar this year so the batteries can be used in assist mode when I pull more than the 16amps of shore power.
the Issue I’m having is when the unit goes in to assist mode to deal with the overhead it then goes back into charge mode and seems to be overcharging the batteries so much so that the multiplus restarts. I want to check if I set the max charge to something like 95% will this fix the issue?
cheers
milo
multiplus ve.bus
