testor90 avatar image
testor90 asked
Battery temperature
Dear Forum!
I have added the Batterytemperature Sensor to my ESS. (As provided with the MPII in the package)
Also connected it and activated everything in DVCC. Also I can see it in VRM.
But how, and where, do i set that the charging of my Batteries is stopped if below 5°C or above 40°C (dumb batterys, with external non communication BMS)
Sincerely.
Multiplus-IIbattery chargingTemperature Sensor
snoobler avatar image
snoobler answered ·
Charger tab on VEConfig.
You need to have firmware 489 or higher and have the battery type set to Lithium.
testor90 avatar image testor90 commented ·
Thank you very much,
i can only see the "stop charger below" window but not above
snoobler avatar image snoobler testor90 commented ·
I'm sorry. I missed the above 40°C part. To my knowledge, what you want isn't offered.
If you had a BMV-7X2, you could use the control relay to signal the inverter to stop charging.
You might want to look into the charge current control assistant. You would need a temp sensor connected to the MP.
https://community.victronenergy.com/questions/74565/what-is-the-temperture-measurement-accuracy-of-vic.html
