delta5 avatar image
delta5 asked
BMS Cable type
I have an Easysolar 11 48/5000 and Pylontech US 5000 batteries
1 The BMS cable I have is W10SCAN30RJ1 is this correct?. Other information specifies a special cable.
2 A voltage sensing cable is supplied there is only one terminal but 2 wires and the connection is impossible to reach with a screwdriver. I this wire needed or is there an internal connection on the Easy Solar 11
lynx bms
nickdb avatar image
nickdb answered ·
It is all clearly documented in the victron/pylon doc "CAN bus wiring" section:
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
