Dilip Kumar TD avatar image
Dilip Kumar TD asked
how feltch data PF and other parameter from ET112 to build node red dashboard
Dear team
I attempted to build my Node-red dashboard using the System parameters, however, I was unable to locate the ET112 parameter alongside other options like PF and MD.
Please give the solution for build own node-red dashboard
Energy MeterNode-REDmodificationsgui mods
Alistair Warburton avatar image Alistair Warburton commented ·
Where are you rying to run this query, and how?
Isnode red on a GX or somwhere external?
Are you trying to use Victron Nodes / Modbus / MQTT?
Is th meter showing up on your GX device? If not are you trying to read it seperatly from Node red?
Please post all relavent system details and your precice requirements to get a good answer.
If you are using Victron Nodes and the meter is properly configured in the GX device as a Modbus device it should show up as an energy meter node! Its data will also be available over Modbus TCP from an external Ethernet connection to your GX.
