jerothle avatar image
jerothle asked
Has anyone used two Phoenix Smart IP43 Chargers?
I have two 12 volt batteries in series for 540 Ah. And, I have two more that will be connected all in parallel, but these two are not in use yet.
I am currently using the Phoenix Smart IP43 Charger, but it takes a long time to get over the curve on charging.
The parallel batteries are being charged with approximately 44 to 46 Amps from the single Phoenix IP43. A 12 volt (low power) blower fan is cooling the Phoenix when charging the batteries. 6 AWG welding cable connects the charger to the buss bar, shunt, buss bar, batteries.
Has anyone used two Phoenix Smart IP43 Chargers on a large battery bank?
Thank you.
Phoenix Smart Charger ip43
@jerothle
I dont see why not if your battery bank can take the extra amps.
In the design there is provision to smart network with other chargers. Although it does not specifically mention other phoenixs.
