northcaptain avatar image
northcaptain asked
Using Cerbo to disable Smart Solar charging
On the Victron connect App its possible to disable charging for maintenance purpose. I have searched in the menu of the CERBO and not sure... Do someone knows if its possible to disable/enable charging remotely through the VRM portal and the CERBO ?
thanks
cerbo gxVRMsmart solar charging behaviour
Alexandra avatar image
Alexandra answered ·
@Northcaptain
As a built in feature through the cerbo menu, no.
But depending on what mppt you have there are other ways to disable charging with the relay and the remote h/l connection on the mppt. You can control the cerbo relay from the VRM.
