Troy Ryan avatar image
Troy Ryan asked
Using a GX device to control Fronius export
I want to control 2 Fronius inverters on separate buildings for zero export.The meter box is in the yard free-standing
Is it possible to set up a GX device and and an EM24 at the meter and use it to only control the Fronius/s with no Victron inverter?
Thanks
Fronius
anthony avatar image
anthony answered ·
I don't think is possible as the zero export functionality is achieved under the ESS settings in the GX device. The GX device needs to see an ESS assistant programmed into a Victron Inverter(s) on the system for this menu option to become available on the GX device. Have you read below info:
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/configuration.html#UUID-634c2829-76e8-4e0a-522b-32bbe2cd1c92
https://www.victronenergy.com/live/ac_coupling:fronius
Troy Ryan answered ·
Thanks, I didn’t consider where the ESS had to live
