Not a Windows guy (100% Mac based) but would like to install an ESS Assistant. I have a Multiplus II, MK3-USB and a Cerbo. Is there a way?
Thx
Thx
No. Assistants can only be installed using ve config. Since you have a cerbo you can use remote ve config through vrm to download and upload config files to/from the inverter. I'm not sure if you can modify the file using a Mac though. Maybe you have a friend with a windows PC? Only takes a minute to change the config and you can do it remotely.
Parallels works to run Ve Configure on a Mac. I know it is a lousy answer but maybe someday VictronConnect will be able to do it all.
In the same boat as you -- I've been using: https://github.com/Gcenx/WineskinServer and you can install and run VEConfigure without issue and way easier than standing up a whole VM instance (especially if you're running a newer Mac with M1 cpu like me)
I'm using the Remote VEConfigure to download/upload the files from VRM. Works a treat! (Example shown, not my actual setup)
51 People are following this question.
