My camper is 30 amp. We are planning to install 3 200-watt solar panels and 3 200 amh batteries. What are the best Victron components to run the system?
The absolute minimum you need if you want PV only is one Inverter and one MPPT. but you really need to provide more info so we can help, like for instance how much stuff you are planning to use the inverter for?
you can go 110v/220v, you may not even need solar panels and you could use a TR ORION and charge the auxiliary battery with your truck/car alternator.
What type of batteries are you all looking at?
35 People are following this question.
