grobalt avatar image
grobalt asked
6 Modules serial with 250 or parallel 3x2 with 150 ?
i would like to to wire 12 identical Axitec 415wp (Axipremium XXL HC BLK) modules -> RS450 does not fit very good based on the excel calculator, so i have to go for smartsolar. No shadow, all 12 modules pure perfect sun in perfect orientation.
Doable is 1x6 (250/60) orr 2x3 (150/60)
2x 150/60 is around 300Euro cheaper than 2x 250/60.
System is 48V and another large AC inverter exist as well with 3 Multiplus.
Is there any disadvantage going with 2x 150/60 ?
Not sure - Admin please assign or create
bunya-solar-pl avatar image
bunya-solar-pl answered ·
I can't see any disadvantage in going with 2 of the 150/60 regs except for larger cable size on the solar side of the reg as will be twice the current as the 250/60 situation. You'll also need some way of paralleling the two strings of 3 panels together. If they have MC4 connectors you can use MC4 parallel plugs.
ahtrimble avatar image
ahtrimble answered ·
I looked up your PV...38v/14a if I read it right.
If you go with 4 strings of 3 panels that gives you 114v / 56a total. That is kinda cutting it close when you are talking ideal conditions and you might exceed the 150/60.
I have the MPPT 150/70 which would give you a nice safety margin/cushion. So you might want to consider the 150/70. And I use 2AWG from MPPT to batteries, fuse and switch.
Something to think about.
grobalt avatar image grobalt commented ·
Thanks for your reply, you would add 12 modules to one MPPT ?
The "issue" with 3 parallel is i have just one cable (6mm, about AWG 9.5) and i cannot add more without creating a huge construction site -> and 3 parallel is up to 40A -> MC4 connector on the roof are just certified up to 30A.
4s3p is exceeding the 150V by far
2 AWG -> i will use 35mm as the maximum is for the MPPT.
250/85 as the online MPPT calculator proposes:
I don't understand why is the website not proposing 250/100 (100 Euro/USD more than 250/85)? Because even that model is limiting / saturating in power (A) ?
as we have with the 250V room for higher voltage -> 6p2
Finally a 3 by 4
If i am not completly wrong, the modules will be most of the time between 10 and 45 C° -> so capped .
Module looks like:
If i follow the Victron MPPT webseite is recommends 85. 85A / 12 Modules is 7,08A per Module which means the MPPT is capped when ~ 500W/m² irridiation, correct ?
