If for example i have a Multiplus that supplies a maximum continuous of 1300w and i draw 1300w which is being supplied from a battery bank. When shore power is connected will this allow further draw? perhaps 2000w?
The multiplus can only power assist its inverting rating from the battery (if sized correctly) it can pass through to loads the max input current of its transfer switch.
If you let me know which inverter you are looking at we can show you in the tech specs in the manual where the relavent information is.
30 People are following this question.
Automatic switchover to Mains Power - not working
recommendation to replace Magnetek Model 6406 Power Converter
How to set MultiPlus to prioritise solar power before shore power, but shore power before batteries?
Program inverter to shut down if shore power is lost?
Boat setup so there are no issues with shore power 50hz or 60hz
