jven avatar image
jven asked
Can you mix hard. rev. 15 and rev. 12 of PMP482305010 in parallel ?
As per the title. Thanks!
multiplus in parallel
nickdb avatar image
nickdb answered ·
What are the serial numbers of the inverters (this also gives an indication of age).
jven avatar image
jven answered ·
Rev. 15 is SN:HQ2039MMQI7
Rev 12 is SN:HQ1946YTBVK
jven avatar image
jven answered ·
But they are the same part numbers...
jven avatar image
jven answered ·
Anyone ? I got a possible deal I wouldn't like to pass...
Thanks
nickdb avatar image
nickdb answered ·
Guidance on paralleling older systems is a bit grey.
In theory they aren’t too far apart, the hardware rev shouldn’t matter as long as they have the same hardware ID, feature set and firmware.
Reality can mean a variance in how balanced/symmetrical they actually are when paralleled because differences in hardware affects how well they work together.
I have been trying to get a better matrix to answer these questions, some just avoid doing this with older systems because they don’t want the risk.
Sorry to be so vague. Best chance of success is to have the same rev, depends on your appetite for risk.
jven avatar image
jven answered ·
I went for it :) Don't have much time to install it at the moment but will come back later...
My reasoning is that even if it doesn't work I'll probably be able to recover most of the value by selling it. I say most of it because unfortunately 2nd hand sites suck your earnings too much nowadays...
Thanks for the info !
nickdb avatar image nickdb ♦ commented ·
@Jven Make the newer one master. Once running, check the output with a clamp meter under load to see how balanced they are. If they are even-ish you're sorted, if there is a larger delta, then just be careful how you load them.
jven avatar image
jven answered ·
@ nickdb Thanks for the reply. I ended up getting only the rev. 12 unit.. Probably a mistake Just posted another question about serial numbers and matching hw rev...
