phillan1 avatar image
phillan1 asked
No power at all, please help!!
Hi, I have a vitron power inverter with a Multipass compact unit. There is no power at all inside the camper van. The Multipass unit has a solid red alarm led and a solid amber charge led. I cannot even Bluetooth into the console. Absolutely no power, everything is down. I am using the same power cord as I used before. Also, when I start the camper van, engine running I also get no power, even the driver console is not working. Please help.
shorepower
netrange avatar image
netrange answered ·
Check the Power Connections AND Fuse in the + Cables ...
I think your Batterys are drained AND you have no Power Connection to your Generator
Is there a Power Switch or Relais for this Connection ?
phillan1 answered ·
Hi netrange!!!
Thanks
We are plugged in like we always have been. Sorry if I seem naive about this
Fuse in the cables? You mean the power cables that feed the side of the camper van? I checked those and didn't see any place for a fuse.
You asked if there is a power switch for this connection, you mean from our home that we are feeding power from??
Oh, so the power cables that feeds the camper van has a blue led on top.of the twist lock part. This is on solid blue. Does this help or does this mean my power coming into the camper van is good?
