nick2185 avatar image
nick2185 asked
PV not showing on Multiplus 2GX
Hi all,
I have a Multiplus 2 GX used as ESS. Seems to be working ok apart from the readings on VRM dashboard. Solar is not showing at all, no orange box even!
I have et112 meter for grid measurement and ac current meter connected to temperature input. Assistants on multi are ESS and ac current meter.
I can't find where to configure the ac current meter.
Any ideas?
Thanks
Nick
solar
Paul B avatar image
Paul B answered ·
you have to add a assistant for the AC current sensor
jamesstubberfield avatar image
jamesstubberfield answered ·
Hi Nick,
We have a customer with a similar issue. Can't see the current sensor, despite assistant correctly loaded and configured on the MP II via VE.config. ET112 meter shows up in Settings, but can't see the data for the external sensor, nor how to activate it.
Let's hope someone can help!
James
