I have a problem installing a 123smartbms in connection with a cerbo GX.
I cannot install the venus-data.tar.gz file on the Cerbo. Actually, this should simply work with a USB stick or an SD card. I have already made many attempts, unfortunately without success.
I listened to the usb cable from the BMS with teraterm, something comes through, even if it's not readable. Maybe I don't have the right baud rate, or the data is not being transmitted in ASCII. So it can't be because of that. Something went wrong somewhere with the installation of the file. I just hope someone can help me here.
Greetings Markus
