I recently learned about the capacitor that some install on the power of the cerbo on 48v systems,
I have the HQ2202 no capacitor on 48v system should I consider adding one and what are the specs I should look for in the capacitor?
Hi @Henk Rademeyer and others in this thread,
Please see here for the definitive statement on this issue;
One of these ones:
Buy 1.0mm2 bootlace ferrules with 12mm pin length to make it all work.
We used part # 178-7305 at RS.
check it here for example
https://community.victronenergy.com/questions/152325/cerbo-gx-geht-standig-kaputt.html
Hi, I am struggling to get the mentioned ones. Attached is the one I can get easily but I don't know if it will work.JRA-85-Radial-Aluminum-Electrolytic-Capacitors.pdf
I am also looking for this capacitor. I could get a 200yF / 100V or a 100yF / 63 V. I guess 63V is a bit to low for a 48V Batterie system? Would 200 yF work as well?
I found this document and on the bottom it states that you should not use a low ESR capacitor, how do you determine the ESR?
2022-08 Cerbo GX power supply issue in 48V systems - v5.pdf
Thank you all for your assistance I will get the cap installed asap.
I would like to suggest to @Guy Stewart (Victron Community Manager) to include the requirements of the capacitor on 48v systems in the online manual of the cerbo gx to increase awareness of the requirements.
Thanks and noted @Henk Rademeyer - there will be a follow up announcement shortly on this issue with more detailed and specific information.
Thankfully the affected units are not as widespread as initially thought.
Watching out for this.
Has this problem been rectified for current production yet. Prefer to wait unitil this is sorted out properly before I upgrade to Cerbo. Supplier her is SA still selling units without even mentioning this issue. When I asked why they are selling them without modification kit they said they have never had a problem.
Hi @Merle.Peter,
Adding the capacitor is no longer necessary with serial numbers that start with HQ2221 or higher.
Most installers will likely not have a problem even with the old stock - it was only in some specific configurations, less than 1%. However in those installation situations where it did present, it would need to addressed or would re-occur with a replacement (due to that installations specific characteristics).
Hallo, bin gerade über den Artikel gestolpert, und froh daß ich meinen Cerbo GX noch nicht in Betrieb genommen habe. O.K. Hinweise wie: "Les doch mal das Handbuch" brauche ich nicht zwingend, da bin ich schon dran!
Trotzdem habe eine Verständnisfrage die jemand der schon tiefer drin ist vielleicht leicht beantworten kann: Cerbo GX ist gemäß Beschriftung zwischen 8 und 70V DC zu betreiben - der Einfachkeit halber wohl direkt am Akku, soweit so gut!
Mein Akku hat 16* 3,2V LiFePo4 => bis max. 56,8V und damit ist das Cerbo GX bei mir "Kondensatorverdächtig" gemäß diesem Thread, denn es hat eine Seriennummer HQ2203*.
Stört es den Cerbo GX wenn ich ihn in diesem System an eine 12V Quelle hänge oder braucht er unbedingt die selbe Spannung wie der Akku um seinen Dienst (korrekt) zu tun?
Wie hoch wäre der Strombedarf (Ampere) bei 12V (oder steht das auch im Handbuch?)?
Ist mit dem 100µF Kondensator wirklich alles erschlagen? Sowas habe ich in der "Wühlkiste", daran sollte es nicht scheitern, aber ich gehe lieber in der Spannung runter wenn das für das Gerät irgendwie besser ist! Gibt es da vielleicht (auch) eine Offizielle Ansage von Victron dazu?
Würde mich über eine brauchbare Antwort freuen!
Gruß TGO
P.S.: Ich hoffe es ist in Ordnung wenn ich auf Deutsch frage - auch wenn hier alles Englisch war, Antworten auf Englisch sind mir ebenso willkommen!
Die Verwendung eines 100uF-Kondensators löst das Problem der Ausfälle, ja, und glücklicherweise auch, denn sonst würde Victron tonnenweise CerboGX zurückbekommen.
Ich habe noch nie davon gehört, dass es von Vorteil ist, 12 V im Vergleich zu 48 V anzuschließen.
Für den Verbrauch bei 12V ist der Strom nur 4x so hoch wie bei 48V ;)
Stromverbrauch eines CerboGX bei 48 V: 0,2 - 0,3 A, d. h. bei 12 V verbraucht er etwas mehr als 1 A.
51 People are following this question.
