ks4z avatar image
ks4z asked
Multiplus II GX Start external device on high demand
Hi, I run a Multiplus II GX as ESS. All loads and the grid are connected to the input.
I have got a non-Victron grid inverter connected to the battery that I would like to use to generate additional power when the Multiplus is not sufficient, e.g. the demand is too high or there is so much solar that the Multiplus can't feed it all in.
I found no way to switch a relay when the inverter is under high load. Did I miss something? Are there other ways to achieve my goal?
Thanks
ks4z
Multiplus-IIRelay
