sweyn avatar image
sweyn asked
GX LTE 4G not connecting
9e9a876e-ee4b-4c1a-a487-6d1247b573d3.jpeg7d1a0a78-ea72-491e-864b-14fd59e17dfa.jpegI’ve connected my GX LTE 4G to my CerboGX and everything seems fine but it just won’t connect properly so I can use the VRM.
Any advice?
cerbo gx4g
4 comments
sweyn avatar image sweyn commented ·
Everything works fine when I connect to Wi-Fi through my phone.
I’m going to bump this up in the hope that someone maybe from victron can comment?
All questions on this subject seem to go completely unanswered.
df32 avatar image df32 sweyn commented ·
Hi.. old thread but hopefully you found a fix? My system worked just fine for weeks but today would not connect and showed all the same errors you described.. hot spot phone is 100% .. lte I can't get back! Any advice or solution would be appreciated .. thanks
dfrenier avatar image dfrenier sweyn commented ·
I am having the exact same issue. Any resolution?
octafish avatar image
octafish answered ·
Is there a LAN ethernet router connected to the CerboGX? I suspect this causes LTE connectivity failures. Would love an admin to chime in…
