dbainbridge avatar image
dbainbridge asked
VRM Portal broken
It appears something has changed in last 24 hrs to the VRM portal and I can no longer view my VRM Portal page with Safari on macOS. The two errors in the web console are:
[Error] ReferenceError: Can't find variable: BroadcastChannel
3c58 (app.c35ee2f4.v1.js:1:525804)
o (app.c35ee2f4.v1.js:1:897)
96f6 (app.c35ee2f4.v1.js:1:1073853)
i (app.c35ee2f4.v1.js:1:269840)
(anonymous function) (app.c35ee2f4.v1.js:1:731005)
forEach
56d7 (app.c35ee2f4.v1.js:1:730989)
(anonymous function) (app.c35ee2f4.v1.js:1:2613)
n (app.c35ee2f4.v1.js:1:433)
(anonymous function) (app.c35ee2f4.v1.js:1:2578)
Global Code (app.c35ee2f4.v1.js:1:2582)
[Error] Error: [$injector:modulerr] Failed to instantiate module vrm due to:
[$injector:nomod] Module 'vrm' is not available! You either misspelled the module name or forgot to load it. If registering a module ensure that you specify the dependencies as the second argument.
https://errors.angularjs.org/1.8.2/$injector/modulerr?p0=vrm&p1=%5B%24injector%3Anomod%5D%20Module%20'vrm'%20is%20not%20available!%20You%20either%20misspelled%20the%20module%20name%20or%20forgot%20to%20load%20it.%20If%20registering%20a%20module%20ensure%20that%20you%20specify%20the%20dependencies%20as%20the%20second%20argument.%0Ahttps%3A%2F%2Ferrors.angularjs.org%2F1.8.2%2F%24injector%2Fnomod%3Fp0%3Dvrm%0A%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A843%0A%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A13452%0Ar%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A13131%0A%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A30495%0AS%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A1549%0Ax%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A30440%0A%24n%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A29487%0Ao%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A10930%0ARt%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A10479%0A%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A92%3A186451%0Ac%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A62%3A26393%0A%40https%3A%2F%2Fvrm.victronenergy.com%2Fjs%2Fchunk-vendors.cee44b72.v1.js%3A62%3A26694
(anonymous function) (chunk-vendors.cee44b72.v1.js:62:28071)
VRM
Alex Imbrea (Victron Energy Staff) avatar image
Alex Imbrea (Victron Energy Staff) answered ·
Hello all,
Since there are quite some users here that are running older versions of Safari and cannot upgrade, we implemented a solution that should also work now on slightly older versions of browsers.
dbainbridge avatar image dbainbridge commented ·
Thanks! It is working again for me.
We are looking into this issue. The latest version of Safari seems to work correctly.
@dbainbridge could you please tell us what version are you using?
We ran some tests and everything should be working correctly in the last 3 versions of Safari 15.4, 15.5 and 15.6.
dbainbridge answered ·
Ah.. I am using Safari 15.3.
Our suggested solution is to update to 15.4 or later. 15.3 has less than 1% market share and we are not supporting browser versions with less than 2% in general.
-ed avatar image
-ed answered ·
Same problem since 18:00 GMT today. Using Safari 13.2
Just checked on my iPad Air and it is also broken when it was working fine. My iPad can not update to any newer than 12.5.5 iOS.
