Florian Mettetal avatar image
Florian Mettetal asked
Initial setup, 240V split. Quattro#2 isn't showing up in VC app
Hello! Phew wiring everything was a job! I hooked up 1 battery with the Quattro's in parallel and they came on as expected. I connect 1 quattro to the other with a rj45, and the next quattro to the mk3 USB controller. Only 1 quattro shows up in the VictronConnect Mac app. But if I change the state from on to off it applies to both Quattro's! I disconnected 1 at a time and each is connectable. I'm just not able to see them as 2 individual units which my vendor says is the first step in configuring the inverters to operate in 240v split mode.
Any suggestions? A jumper I'm missing or something?
quattro 10kvasetup
Florian Mettetal answered ·
I didn't have the issue with the windows app, I think there was an issue with the mac app. There is a setup walkthrough for split phase that wasn't being triggered.
chenirl avatar image
chenirl answered ·
Just a suggestion, are the firmware's the same version on both?
if not update both individually.
Alexandra avatar image
Alexandra answered ·
@Florian Mettetal
What you are seeing is correct. Click on the single inverter you see amd follow through with the instructions.
There is a walkthrough video on this page.
The video is for 3 phase but really it is the same thing.
