Hi can someone advise what the problem
m is here….. App says bulk and float and abs working but 0wh being used and the fridge is on constantly? Some says it will say no abs, float or bulk being used.
thanks in advance
thanks in advance
There is no problem.
The MPPT has no idea what loads you're using as it only knows what it sends out the battery wires. The consumption row is for units with load ports where the MPPT can actually see the current being passed out to the load ports.
If your fridge is not connected to the MPPT load ports, there is no "consumption."
Provided you reach float every day, you can conclude that your consumption is approximately equal to the energy provided by the MPPT, e.g., days 1 and 2 were about 335Wh of consumption.
26 People are following this question.
