Hi @Chris Webb,
It depends on the kind of monitoring you want to do.
There can only be one meter in “grid” mode.
There can be multiple meters in “AC load” and “AC supply/PV inverter” mode. So those could count.
Perhaps you could draw a diagram of the AC wiring configuration?
Do you have a MultiPlus 2x120V? It should offer proper split phase monitoring at the inverter stage. It not mentioned, and how you are using the AC shore supply might change the suitability.
Hi Guy,
One point I have to remark.
If you attach a shore power or another type on “non-solar” power source and do configure this as PV inverter, than all the harvested power will be added to solar power which is not correct in this case.
In this case the harvested power should be added to generator, or not?
Regards
Hi I am sorry I didn’t think this post was responded to I have created a diagram of the boats electrical system. Thanks for your help in advance
31 People are following this question.
