2 x ve direct to vedirect, one for mppt one for the shunt
2 x rj45 utp for ve can connection on ve can mppts. Mppt to mppt then one to the cerbo.
1x RJ45 UTP cable for the inverter
I have not specified lengths as I don't know how you are routing those
Also you need to change the mppt negative to the other side of the shunt. (One marked loads). The battery terminal should only have the battery negative on it.
28 People are following this question.
