denzel avatar image
denzel asked
Understanding Multiplus 1 Max Cont. Output (24/3000)
Good Day,
As per the Datasheet for the Muliplus 1 24/3000/70 it states the below .
Cont. output power at 25°C (VA) (3) = 3000
Cont. output power at 25°C (W) = 2400
Cont. output power at 40°C (W) = 2200
Cont. output power at 65°C (W) = 1700
Peak power (W) = 6000
Does the temperature in the above refer to the Temperature of the Inverter or the room/location temperature ?
My setup - 3 Multis in Parallel - I have inverted to almost 7000W with no issues however that leaves me wondering can the remaining 3000W be using if the temperature was below 25 'C ?
Regards
multiple inverters
kevgermany avatar image
kevgermany answered ·
Temperature sensor is internal to the multiplus, but as you have specs of full output at 25C, the fan must be able to provide sufficient cooling at 25C.
Loading up. The answer is, it depends. Watt ratings assume a power factor of 80%. Unless you have the equipment to measure all devices and then do the maths... Some loads will cause overload well before the theoretical max. Also when you have power assist on there's more available.
In general stick to the Watt ratings.
denzel avatar image denzel commented ·
@kevgermany Thanks for the response . Im left with a currently dilemma, I need to sometimes get to 8000 w inverting power so should i use "Power Assist" or add another inverter to the system
kevgermany avatar image kevgermany ♦♦ denzel commented ·
Power assist is on by default. As this is dependant on the nature of the load, there's no straight answer, sorry.
Suggest you try increasing the loads in as realistic a way as possible.
