greagoir avatar image
greagoir asked
System setup Help
I apologize in advance for the help I'm asking for.
I have a 100/30 SmartSolar controller, 1x SmartShunt 500A, 1x Energy Smart Battery sense, 3x Renogy 12v 100Ah AGM (parallel), 6x HQST 12v 100w Mono panel in series to parallel (24v) and 1x Battery protect (Not connected) in a 5th wheel camper.
I just switched from a EPever 30A controller which was charging fine, according to the controller. My data now is all over the board and my bank isn't getting charged properly. I know its alot to ask but what a need is a step by step, entry by entry instruction on how to setup my system. A link would be great as I realize this is alot to ask for.
Thank you all for your time.
Cheers
Greagoir
system design
jm0278 avatar image
jm0278 answered ·
Are you using Victron Connect to see what the SmartSolar and Smart Shunt are showing? If so, what does the MPPT show?
In addition to that, it would help if you post a wiring diagram of your components (or a description of how you connected everything).
And screenshots with the current settings for all devices.
