stijnl avatar image
stijnl asked
ffmpeg installation package on Raspberry Pi
I would like to install the ffmpeg package on venus OS with raspberry Pi.
This package is not included in the standard repository of Venus os, i tried:
opkg install ffmpeg
i also tried to find a correct package which has the .ipk archive, but no result.
Does anybody have succesfully installed ffmpeg package onto a raspberry Pi with Venus OS?
Venus OSRaspberry PiNode-RED
jeroen avatar image
jeroen answered ·
Well if you time + a decent computer, have a look at https://github.com/victronenergy/venus.
make raspberrypi2-bb
bitbake ffmpeg
The ipk will then be in deploy/venus/ipk/.. One caveat, there is a license issue apparently. You need to add
LICENSE_FLAGS_WHITELIST = "commercial"
to build/conf/local.conf. I happily leave it up to you what that implies.
stijnl avatar image stijnl commented ·
Thanks for your reply,
I checked the link but i think it's far above my level of knowledge about those topics. and yes also i don't have a decent computer and time.
is was hoping somebody already had the correct ipk package that i could use, the ones i found were for openWRT routers and didn't work on raspberry
Rene Mullie avatar image
Rene Mullie answered ·
Just curious, whatfor do you want ffmpeg running on Venus device?
stijnl avatar image
stijnl answered ·
I would like to acces a Ezviz IP camera from my Node Red Dashboard.
the threaths that i went through for accessing IP camera's in Node Red all involved getting the ffmpeg package.
