denzel avatar image
denzel asked
Multiplus 1 - Parallel setup 3 inverts - Chip version - .HEX and .VFD
Good Day,
Im installing my Multiplus 24/3000/ 70-50 units in parallel . I noticed now that 1 out of the 3 units have a slightly different chip
All 3 unit can go up to the same version 4XX firmware.
Will the .HEX chip prevent a successful setup ?
Inverter 1 - 2610152.HEX (PMP243021010)
Inverter 2 - 2610158.VFD (PMP243021011)
Inverter 3 - 2610158.VFD (PMP243021011)
Regards
multiplus in parallel
wkirby avatar image
wkirby answered ·
Those are all the same 2610yyy, so that should not be a problem and they are all compatible with 400 assistant firmware too.
The 152 is slightly older than the 158 probably due to the unit being produced earlier than the other two, but they will all be able to go up to the same version, 2610497 is the latest one.
